Any recommendations on an in stock audio A/D and D/A? This is to get audio in and out of a DSP chip. Looking for 24 or 32 bit capability with either I2S or TDM serial communications.
Just checked it out. It’s good to know what people use.
Ideally I need one chip that does ADC and DAC, don’t know if that is possible at 24 bit.
That's a codec. Lot's of those available. For example TI has a lot of options: https://www.ti.com/audio-ic/converters/codec/overview.html
Also consider Cirrus Logic's CODECs. The CS4272 in particular is used in many very well-regarded prosumer USB interfaces.
Thanks Mark for pointing that out, yes it seems exactly what I need. Will also take a look at the Cirrus.
https://www.roland.com/au/products/ua-1g/Ideally I need one chip that does ADC and DAC, don’t know if that is possible at 24 bit.
- Digital Line Level
- What A/D and D/A converters are you using?
