So I picked up this active subwoofer wharfedale wh D10, but it only works on 220v. Its working fine, except I don’t have 220v.
Getting an external transformer would be my last option, is there an “on board” solution, a doable one?
I haven’t been able to find schematics on this one…
The transformer is soldered to the board, but I don’t know if it is equipped with the primary 120 winding…
Any help would be appreciated…
thanks
thanks
That is a switching type power supply and is probably designed for use in any global market (any mains voltage). Most (like a laptop PSU for example) work with no adjustment. This one may work like that with no adjustment required or it may be configurable on the board itself.
This is all hypothetical and without detailed examination its impossible to say...
Clues would be looking how those two big reservoir caps are connected. They might be configurable as a series connection for 220/240 volts and in parallel for 120 volts. That might be possible with link options on the board. Alternatively it may need no alteration and already be OK at 120 volts. Have you tried it at 120 volt?
More rarely the caps can be configured (by links) to operate in a 'voltage doubler mode' for the lower AC line voltage.
All the above is 'at your own risk, no guarantees'.
It sems to be a standard arrangement then and you just fit the new link which will reconfigure the voltage doubler arrangement (as in my image). It is the usual way of doing it but I never say with 100% certainty without having the board in my hand to spin around and check for real.
Having said that I'd be reasonably sure it is OK... fit the link and power it up![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This is a Class II device (not to be confused with Class 2) and does not require grounding.
https://www.moonsindustries.com/article/what-are-the-difference-between-class1-class2, class I-class II
Nor the original 110v or the 220v, or my other subwoofers have a ground…. But do to potential hazzard, just in case, one has to be very carefull…. This is how I listen to Beethoven and Vivaldi… allways checking the temperature… you never know
by the way, it was all sarcasm. Just in case, you never know!!! Cheers
- Power Supplies
- Wharfedale subwoofer on 220v only. How can I make this 120v?
