WF55 help needed
I just started Amp-maker's WF55 amp build. It's simplest possible start and I'm finding it tricky 🙁 ... haven't soldered anything since I was 13. Anyway a little messy. However it's coming together. I'm adding two mods: Tone control and VCB - both kits provided by Barry
Can anyone share photos of the completed chassis so I can see how people have fitted the three potentiometers in? I have the three along side each other - but I just realized that the knobs will hit each other...I can change them for small knurled aluminium ones so I guess that's not a problem. However I'm also anticipating a real problem sqeezing in the two VCB capacitors over the volume potentiometer
Any photos/helo would be really appreciated....and any other advice
This is a Guitar Amplifier on the Tubes/Valves threads area.
I had to search the web for a WF55 to discover that.
There is also an Instruments and Amps threads area on diyAudio.
Perhaps they have more ready information on the WF55 amplifier.
