LOL is evryone getting back their tax returns???????? I looked on ebay and this was a high number I thought for a proxima 822C
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2725806286&category=41843
Granted it came with the OHP but still seems to be on the up swing.
Yeah that is a rip off, but the panel does have 200:1 ratio which is pretty good for a projection panel. I think the reason it went up so much is because the overhead is powered by a 575watt osram metal halide bulb.
ebay items
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=25321&item=2725092934
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3319&item=3021012575
Are these decent buys? I missed the top one by about 10 bucks. I am needing to know how to use the bottom one if there is no composite RCA hookup.
UM the polaview is ok Its allready been sold( are you the high bidder)? and the ZX panel IS NOTHING I have ever seen or even heard of, So Honestly I dunno about that one, I have a Telex M2x that I no longer use. I could sell that to you, make me a offer. Other then that I cant be of Much use.
The one on top looks like a clone of the nview viewframe spectra pro... not a bad panel if i recall.
RCA to VGA
No I was not the high bidder on the polaroid. I did bid on it. Does the Telex have an RCA input? I actually have a panel that does not have RCA how do I convert it? How much do you want for it?
Video Freak said:UM the polaview is ok Its allready been sold( are you the high bidder)? and the ZX panel IS NOTHING I have ever seen or even heard of, So Honestly I dunno about that one, I have a Telex M2x that I no longer use. I could sell that to you, make me a offer. Other then that I cant be of Much use.
Hey yes The panel has a RCA input But It dosent work for some reason, The card is Installed in the panel etc But I cant seem to get it to work, I only see snow when I connect something to that Port, The vga In and out works fine, But if you allready have a panel without a Video In It dosent make sence to get another one, Unless your panel is just really old or something.
How do I use it?
What do I need to buy to make the VGA only style one work? is there some kind of converter that I need to buy?
Yes you can Buy a converter, Something like the TV 3000 from AVtoolbox.com would be Ideal, It has A TV tuner built in etc. If your still Interested In The Telex panel Email me at BBingLife(AT) aol.com use the @ symbol in place of the (AT)
Re: 99.00
there are ones like this
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3022007972&category=21169
but i don't know if i'd trust them. also the TV-3000 has a line doubler. that's also nice i've heard.
matthew
JEvans said:a hundred bucks!!!! wow kind of alot! is there anything cheaper?
matthew
yes It is a Bit of Money But personally I have panels with RCA input on them and It still looks better from a DVD off the pc going through the vga Input then a DVD coming from a progressive scan player through the RCA cable.
Video Freak said:LOL is evryone getting back their tax returns???????? I looked on ebay and this was a high number I thought for a proxima 822C
Also I lost three auctions in a row, and I really wanted to win! 😉
That makes sense. RCA is "componant" which combines all of the video signals into a one composite signal. They need to have made a panel that would break the signals down. They do make a composite to DB15 or VGA connector... Dont know if the quality is harmed but it is an idea.
not that I know of, It would be a problem in that the scan rates I believe of a usual vga signal and the rca output are different, thus the need for the 89.00 video to vga box.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Well prices are going up again It seems on Ebay
