Welcome to the new diyAudio platform - feedback wanted!
I suspect that's what is happening. I've completely changed my settings here and as soon as I log out, the forum pops back to its default look.
Log back in and "pop" it's back to the way I set it. So you have to be logged in to see your appearance settings. Only Jason and the Development team know if that can be set by a cookie. Maybe it can be.
Just curious, a number of people have mentioned this problem. Why would you read the forum without logging in? Are you reading on a shared device?
It can be, it's quite common.
To flip the script: Why would I log in if I'm only reading? Normally I only log in if I'm posting something.
In my 16 or so years and I don't know how many 1000s of hours on this forum, it's very rare that I'm here and not logged on. Of course mod duties need a log in, but even just to read and browse I don't know why you would not be logged in.
Is it because you are using a non secure computer or device? Something shared perhaps?
I'm an old-fashioned IT guy and still adhere to IT rule #1 : Use lowest possible access rights to do the job. If I can read posts without login (as this is a public forum) it's incomprehensible to use higher access rights than needed. I don't login as root on my linux machines either, unless really required.
Beautify/UI options should bind to cookies, not only to log-in state, for the same reason.
On mobiles, login is tedious for me (I'm very bad/slow at typing on a mobile and avoid it as much as I can).
@jbau Well at least on the old forum you had to be logged in to see images. And being logged in shows you what you have and have not read, takes you to where you were in a thread and other things that I find important. The only reason I ever visit not logged in is for test purposes. I find not logged in to be a much lesser experience.
So I find it interesting that other people prefer to read while not logged in.
Not even close to the same, but you know that. Typical standards today are that personalizations bind to un-authenticated states only if that is the intended default state, or only state.
Regardless, if @Jason wants to pursue this I personally hope it can be done without changing the public default theme to classic.
Totally agree. This is really unfortunate. I'd was about 1/3 of the way through the incredibly long 10F/8424 & RS225-8 FAST / WAW Ref Monitor thread & now it's become virtually incomprehensible with so much of the image content not visible. Can this be fixed, please!!!
And to think I used inline references to DIYA hosted images because I thought they would be more robust and less prone to broken links in the future (future proofing). I do hope this gets fixed because there are literally hundreds of images that are important to the build and construction of this and other projects that reference inages from DIYA. I am not sure how a migration software, thinks that migration means the links get appended a new and different address .xxx extension to every referenced url link?
Even the root directory of the forums was changed. My old bookmarks for all the forums stopped working because they are all different now. The longer this persists, the more likely that this is the new url.
It used to be a very standard url that went something like this: http://www.diyAudio.com/communityforums/forum_name
now it has become something like this:
http://www.diyAudio.com/community/forums/forum_name.xxx/
The xxx probably sequential numbers on how the software scanned and “migrated” the website to a “sandbox” website. Final migration probably was meant to go back to original url but instead the sandbox url was kept as the new standard.
I am missing the spelling check. I did like it, though. Can we have it back?
I am not a native tongue and when I write fast I sometimes spell the word how it would sound in my language. I loved the check. Some words I just had to look up everytime to know where they have additional characters that you don't hear.
