Heres a link to an album of my dad's watt/puppy clones, there dusty but visible tell me what you think!
http://community.webshots.com/album/379232684rbsWHK
Re: Hmmm...
Isn't that a good thing?
The Focal is rather unforgiving of any grittiness upstream, but I've not heard a soft-dome that I'd prefer (although I've not heard the ring- radiator as yet.)
Arne- whats your problem with it, if you dont mind me asking?
Cobra2 said:
The Focal unit is no ScanSpeak Revelator....
Arne K
I do not like the Focal unit much...I think it gives some coloring to the sound, and is not as airy and detailed as the Revelator in my AudioVector S6.
Female jass-singers looses the "magic".
I do not need any "grit-filter..."
The RingRadiator is over-priced, not better sounding, just much harder to implement...
Arne K
Arne K
need help...!
Since my "clones" are gathering dust, it would have been nice to modify them into something usefull...
As they now are with above mentioned drivers, and filter is a copy of this:
http://www.users.nac.net/markowitzgd/david/wap-x-o.gif and this:
http://www.users.nac.net/markowitzgd/david/watt-x-o.gif
-I have been told that the 0,33mH is too small in this setup.
OK, easily changed. But still don't like the midrange. So I need a totally different driver...but what is usable here?
And then, what mods should I do to the filter?
Or should I change the whole speaker into something similar to the "Poly Natalia" ? http://www.blackdahlia.com/polyarti.htm
Suggestions are most welcome...
Arne K
Arne K
Re: need help...!
don't understand 0.33mH is too small see :
http://www.users.nac.net/markowitzgd/david/wattcrossover.htm
A totally different driver is not really on.
Or the Poly Natalia - you can't get the drivers.
Best re-use would probably be as follows :
Rebuild the head unit with a 6.5"/1" design of your choice.
Bi-amplify with active bass/mid slopes to the bass unit.
Probably best to use active baffle step compensation for the
mid/treble head to increase headroom, but more complicated.
/sreten.
Arne K
/sreten.
- Watt Puppy Clones
