Hi Baldin,And for implementation with lower capacity FETs like IRFB5620 I can just use a lower current version of the ZXGD ..... probably will benefit FETs like these also.
For such fets, I don't think you would even need external driver to IRS. How fast do you want to switch such fets? Another question would be, how much of additional delay can you get ways with. It seems that 10ns is pretty much minimum here.
Hi Mario
What load are you using?
Even for 2 ohm I think you could and should use lower rated MOSFETS.
E.g. IPP200N15N3 G, would give you 50A and a load of only 1820 pF, and with Vds on 150V should be ok for your +-52Vdc
And it can be driven without the buffer ..... also BD139/140 is not the best for this .... better to use SMD types to reduce trace lengths and parasitics
Gate voltage on 10V should be ok, but why is it dropping? And from what level?
And distortion at lower levels does not sound right at all
You need to read teh app notes and data sheet for IRS2092 ... there you can find the calculations for OCP trippng point
https://www.infineon.com/dgdl/an-1138.pdf?fileId=5546d462533600a40153559a077610d1
page 10
Thanks for the reply.
I'm using 4 and 3ohm (occasionally 2ohm) loads.
VCC is derived from the negative rail via a zener diode and a bjt, just like in IRAUDAMP7S.
Perhaps it is for this reason that VCC tends to drop so much (in fact, the bjt / diode zener warm enough but not in a worrying way).
As for the low-volume distortion, I tried everything, but I could not eliminate it.
I thought it was a difficulty of BD139 / BD140 to drive them, but I'm not sure, they are declared with 1.5A of capacity and I think that for a single pair of IRFB4227 they should be sufficient; then, if there are other factors to consider, I have not understood it yet.
Might be worth considering reducing the value of the series resistor "in front" of the zener/BJT combo?
The thing with the BD139/140 is that, being through-hole parts, the minimum leg length is still a good few mm, and at high frequencies (and high rise/fall times), every bit of conductor length (and as such, inductance) matters.
News, AMAZING!
Reading the application notes, I understand how to set the threshold for overcurrent protection, both for the low side mosfet and for the high side mosfet.
I realized with amazement that on the low side (ocset) was already set well (with only one pair of IRFB4227, the maximum current that can be reached is about 45 Ampere, so you have to create a tension of 1.08v on OCSET and it was already ) but on the high side (csh) an anomaly had occurred (I had almost 4 volts) even if the voltage divider R2-R3 was correct;
Incredible but true, it was the blocking diode that was not suitable, in fact I had used a 1n4004 that had a Vf too high and was very slow; I replaced it with a diode wall that is very close to the characteristics required with a Vf of 0.7v.
In one shot I solved the problem of low-volume distortion and even the self-resetting of irs2092.
It remains to create a worthy power circuit, because with what I have now, I can get about 150w rms at 50hz without distortion at 4ohm (28.2v - 5.01A) then you start to see a lot of distortion because the rails are disappointing.
I think I will make a power supply that can produce at least +/- 78V with many Amps.
thank you for this information. I also have been struggling with the IRS2092. Can anyone tell me what will replace this chip with same functionality? I ask because my supplier has long told me that the 2092 is no longer in production. -hjp
Only the DIP-packaged version seems to indeed be discontinued; the IRS2092S (the SOIC version) is still "active and preferred".
Audio' 'Driver' 'ICs - Infineon Technologies
thanks for the clarification. I see many schematics here for this amp. does anyone have a good foil pattern for a 500w with none of the problems shown here? I would be grateful for a pic or pdf .
Incredible but true, it was the blocking diode that was not suitable, in fact I had used a 1n4004 that had a Vf too high and was very slow; I replaced it with a diode wall that is very close to the characteristics required with a Vf of 0.7v..
If you look at the 2092 datasheet it gives a diode to be used in that position.
does anyone have the gerber files for this amp (iraudamp9)? thanksLook up the iraudamp9 and iraudamp7 pdf's from IR.
They include pcb layout.
I have heard of people using the 2092 with the 4227's and it working OK.
If so the gate resistors would have to be as low as 4r7.
I never went below 10r and had resetting problems.
Once I used gate buffers the problem went away.
yes its working perfectly
IRS2092 with Irfb4227 (240khz) 63v-0 63v max 70v
and set max pwmlimit 85%
YouTube
YouTube
I had it working with no buffers but on very high volumes it would start to reset the 2092.
What size gate resistors did you use ?
Have you tried it on full power ?
Get in touch with IR tech support and see if they can supply them.
I have them now and thank you. should I post them here? they have not been 'field tested' yet. -hjp
what wattage on the 4r7's please?
I don't see why not.
I used one watt resistors on the gates.
if you use more than 65v it's stopping ,,thats true
I use 6.8ohms gate resistor (IRFs4227 has 3.8 ohms internal gate resistor)
----total 10ohms
2.set overcurrunt setting to more than 100A
3.63v is good and safe for long time uses,,,,,
use 2ohms speakers (Irfs4227 drive its easly) for 400W
4.output limiting--most important thing if you use 63v power supply you have to set maximum output voltage to 48v peak ....safe and no heating
issue
5.I use only 40V peak (soft clipping)
thank you for the info. I am getting close each day to finishing this one.
- Class D
- Warning IRS2092 and IRFB4227
