Wanting to build a new preamp....what design?
I am getting the itch to build a new preamp. There is nothing really wrong with my current 124B common cathode resistive plate load preamp but I'd like to try something new.
My current setup is as follows
- Systemdek IIX (Rega RB330 arm) with Sumiko Songbird MC cartridge (0.5mV) ->
- Pass Pearl 2 phono (55dB 562Av) ->
- 124B common cathode preamp (22dB 14Av) ->
○ Pass FirstWatt F6 (input sensitivity 2.83V) ->
○ Anthony Gallo Subwoofer Amp ->
- Anthony Gallo Reference 3.1 speakers
Some of the things I'd like in a new preamp
- Low gain, based on my setup I need ~10Av of gain
- Low impedance output (input impedance of the F6 is 100K)
- Design that isn't super picky about PSU design
Because I just want to have fun building a new amp here are a few things I am going to try and incorporate 🙂
- Wood exterior chassis
- VU meters
- Input relay switching
- A volume control other than the Alps I've usually used
Thoughts on some design to look in to?
I was looking at the Akido/TubeCAD CCDA design, seemed intriguing.
The best sound I have yet found is a 2a3 or 6B4G preamp. Low output impedance, plenty of drive.
An easy tube to work with and plenty of schematics and data online. 2a3 with AC filaments or probably even better, 6B4G with Rod Coleman's latest filament regs (Lyrima audio). Could be a simple resistor load with cathode bias and a DC Link bypass cap. Or active load, plate choke or OPT.
I find the sound with a 6B4G with Coleman regs very detailed, dynamic and smooth. Love it.
