I searched the net for "hc2a relay" and over 100references , including your post, came up. US$20 on ebay or cheaper from a number of vendors. E
Oh wow! Thanks mate,I really appreciate your help! I was getting a bit worried about tracking one down.Thanks again.
I looked on ebay but there was only one HC2a relay for $50 from the U.S. so I ordered this JQX 13F 2Z DC 24V Coil 5A Plug IN Electromagnetic Power Relay 8 PIN | eBay for $5. It looks to be DPDT,5A,24V.Would this be OK to use,the original is 3A and has two voltages 24V & 30V?
The Panasonic HC2 series is an industry-standard relay available from every manufacturer (P&B, Omron, Zettler, etc.) under their own part #. The one you picked should work, but the pins are 3/16" or 1/4" quick-connects instead of pc-mount and it is DPDT (form C) rather than DPST-NO (form A). You can find info at Digikey, search for 255-2776-ND and then the datasheet pdf. E
Thanks for filling me in on this MM,otherwise Id never know this stuff? It gets me so confused trying to figure these relays out! Dodgikey wants $AUD65 including postage so Ill just trim the pins on the $5.18 one Ive got coming from Hong Kong.lol I'm trying to keep the cost down for the owner because he is an old age pensioner, I'm only charging him for the parts that I have to buy for the amp Ive had a lot of new parts laying around that Ive used transistors,caps,etc... Now Ive got to figure out the transistors and their subs,that's always fun.Ive got some new MJE15030,MJE15031 to sub for 2SA913 and 2SC1913.Ill search around to find out what other people have used for subs in this amp?The Panasonic HC2 series is an industry-standard relay available from every manufacturer (P&B, Omron, Zettler, etc.) under their own part #. The one you picked should work, but the pins are 3/16" or 1/4" quick-connects instead of pc-mount and it is DPDT (form C) rather than DPST-NO (form A). You can find info at Digikey, search for 255-2776-ND and then the datasheet pdf. E
