Brian Guralnick said:Well, I prety much gave up. I guess I will use a transformer.
'Bout time you came to your senses. 😀
Q1: Which companies make these high performance line matching transformers?
Jensen, Sowter, Lundahl, and Stevens & Billington to name a few.
Q2: With a transformer, should I buffer the output?
Not necessarily. The output will see pretty much the same impedance it'd see otherwise.
Q3: Using a transformer would make life extra easy for integration into the Balanced Zen Pre-amp. However, I do not need the signal gain, would a simple voltage follower buffer make things any better?
How do you mean? A voltage follower buffer where? In lieu of the Zen?
Q4: Are there any worthy pre-amp output buffer stages which can drive headphones?
Sure. Take a look at some of the projects over at Headwize.
se
