Wanted: Crown K2 service manual or schematics
Well... I have the schematics kindly offered by another member but have not the complete service manual.
If you have it complete with Pcb drawings I will appreciate.
What I really need is the Crown Itech service manual. It seems that is impossible to found in this corner of the planet.
Your K2 is already repaired?
It is amazing how they do the amplifier without short circuit protection!:cuss:
Really, do they? I can't imagine a professional amplifier (namely from crown) out in the wild without at least this kind of protection! But since I have never seen the circuit diagram I'm not in the position to call this into question ... It just sounds weird to me. :apathic:
But now to something completely different:
These amps seem to have an auto-standby function, switching the amp off when there is no (better: insufficient) signal and back on when there is sufficient signal. At low listening levels this feature becomes really annoying, the amp switches off at still audible levels.
Does anybody of you know the trick to disable this, perhaps a jumper somewhere inside the amp?
The manual don't even mention this feature! (AFAIR) 😕
Any hints from the service manual owners?
Cheers, Ralf
Hi Vek
It is not completely unprotected but it is near the same. They have a kind of “current Limiter” after the power stage.🙄
The output power stage is not directly and real-time protected as it should be.
About the “self stand-by” feature I have not adequate amount of information to help you. Sorry…🙁
I can send the service manual... Anyone who wants it, let me know your email.
Also I believe Crown will soon be posting the manuals on their site, since they discontinued the K series this past Summer.
And yes, you can disable the standby, but i don't recommend that. You can change R15 on the input module to 845K and you will get 56 seconds of delay instead of 6 seconds.
The next issue I'm up against is getting some replacement FETs. The Fairchild FQP16N25C is what I ordered, hopefully it will work. Crown matches the transistors for gain and other specs, but they want over $6.00 each for them. That would be over $50 for one output module worth of transistors that I risk blowing up again if something else is wrong.
Maxxarcade said:
EDIT: I'm getting the emails back... file is too large :-( Hmm...
How big is it? Must be some MBs...
Perhaps zipping the file would bring it a little bit down in size.
Another possibility would be to upload the files somewhere and send us the link by PM 😎
Maxxarcade said:
What is the size limit on your email? The file is about 10.3MB.
I fear my limit is 4MB per email at this account, feel free to use ralf.simon@retroton.com instead. This one should work! I didn't expect such a big file ...
lumanauw said:
Why is that? Is there something wrong with this amp? What is the replacement model?
AFAIK Crown I-Tech Series http://www.crownaudio.com/amp_htm/itech.htm
Not a direkt replacement, but similar technology, this time combined with switching power supply, DSP...
Vek said:
Why you don't recommend this modification? :scratch: Please elaborate a little bit more ...
The amp will draw over 150 watts at idle and decrease the life of components due to heat. Of course if you're using these at home, where continuous use will not happen, this may be ok.
Also, for anyone replacing the output FETs with Fairchild FQP16N25C parts, there are some components that need changing on the main board if you have an older amp. Let me know if you need it and I will send.
Vek, I'm sending the manuals now, and I included the instructions for using newer FETs as well.
mrx23 said:
Can somebody put the service manual on a free webserver (and put a http link from it to the forum)?
It much simplier than emailt to everybody.
Please upload it!
Thank you!!!!!!!!
Normally I would do this, but I'm already on the virge of getting yelled at for playing with these amps at work, so I have to stop for a bit🙂
Vek, since you have the complete set now (at least you should get it soon) can you upload it somewhere?
Please upload it!
Thank you!!!!!!!!
You've got mail 😀
Thanx for sending a second time, everything arrived in good condition 😉
Sorry, I have no ad hoc access to webspace ...
But as I sent the stuff over to mrx23 hopefully he can do it! (took me two trials, then i splitted the file like in good old floppydisc days, email is not made for something big like this)
Fet Changes...
Maxx,
Would you mind posting the changes necessary when replacing fets here so everyone has access to them?
I also have one of these amps and knew about the resistor change to increase the auto standby time. However, I don't know about other required changes if I ever need to fix mine.
I would also second the request that someone post the service manuals somewhere so we have a resource for repair if we ever need it.
Thanks, 😀
