Hi Ken,KenP said:Would that work with a p3a? They specify 25-0-25 minimum.
I went and looked at p3a at Rod Elliot's site. I couldn't find where he suggests a lower limit for the rail voltage except on the initial power-up where he says
He also limits the upper rail voltage to 35VDC when driving a 4ohm load. With this transformer you'll have about +/-32VDC rails, which should work fine.When power is applied, check that the DC voltage at the output is less than 1V, and measure each supply rail. They may be slightly different, but both should be no less than about 20V.
Where in Canada are you?
Rodd Yamashita
