Wanted, 4 or 5U Chassis for F5 Power Amp
I realise now that I built my first F5 with heat sinks that where too small. Dimensions are 350x100x40mm from Conrad in Aus.
However the four output transistors are still working nicely. Temp on the heatsink is 52 degrees / Celsius (125.6 F) nearest the transistors. I will sell these on the forum as soon as I have re built my F5 power amp.
I would like to buy a chassis made by HiFi 2000 in Italy.
Size 4U or 5U chassis would be great and accept as its used it may have some holes in. Min dimensions 400mm x 400mm x 165-210mm height.
However ideally and I know it’s a long shot, I would like to buy the new style 5U Deluxe chassis with all the holes drilled.
