Want to try OB-need suggestion for plans
I suggest to keep the drivers isolated, whatever a tweeter from the woofer
or the woofer from the ground ( which is difficult because OB likes to have
1/4 pi reinforcement ). Not strings or low elasticity chords but use rubber bands. The best thing to start from is to build a frame ( sort of....a dolly)
and ...
From the technical electronic/ transducer part, I'm more well versed for 3 way design, where active crossover plays a part too: that's why I suggest to take some existing 3 way speaker with sufficient wattage . or use a 2 way, but the tweeter is usually crossed too low.
Because OB ....:cannotbe:
I've never built OBs with 2" think baffles, but I've seen it done. Seems to work well.
It's fast and easy to knock together some baffles out of ply or OSB. Why not start cutting wood instead of thinking about it? What you waiting for? 😉
