want to optimize my bass guitar cab
Guys, I think I already know the general answer but I wanted to check and make sure I'm in the ballpark.
I have a 2x10 sealed bass guitar cabinet I want to port.
The drivers are meant to be in a ported cab.
I have all sorts of calculators for figuring out the size and length and I have all the speaker parameters and I think I'm ready to go but I do have one question.
The two woofers are essentially in separate cabinets with a solid piece of wood splitting the cab in two .... there is a small opening between the two sides where the jack plate is ... but only about a 2x1 cutout.
Ports will have to go on the back
The easiest thing to do would be to simply use two ports, one for each side.
So my question is when calculating the port size/length do I just treat each side as a separate cab or do I figure it out based on the entire cab volume?
And if it needs to be the entire cab then how do I plug in values for two drivers?
I'm probably overthinking this and imagine I should just treat each driver as being in its own enclosure since they basically are.
But before I cut holes in my cab I wanted to run it by the experts.
