Walter's handcrafted AlephX cases
> If you're looking for Hochleistungskühlkörper and want to pay shipping from Germany, those are great.!
For those who do not understand German, Hochleistungskühlkörper means high power heatsink.
The heatsink listed in ebay are Fischer SK440. They are ONLY good if you use force cooling, as the fins are too close together, and also too long for natural cooling (flow resistance too high). Thermal resistance is quoted (as per catalog) at 0.035 degC/W, assuming a flow velocity at 5m/s (!!!) and a temperature difference to ambient at 80 degC.
I doubt many of you would want to run your heatsink at 100 degC and with so much wind noise. So be warned.
Also for anyone who is thinking about shipping heatsinks abroad from Germany, we actually tried to help a friend to order some heatsinks from a German supplier (not Fischer) and asked them to quote for the shipment to Asia. While the heatsinks themselves cost 40 Euros a piece, which is very reasonable, the shipment cost for 4 heatsinks (22kg in total) by UPS was some 500 Euros. So unless you live in EU countries, or you have friends in Germany, I think you might find it not too easy. We were very surprised ourselves how difficult it was. In the end, we ordered in Germany and shipped them by post, paying 2 time shipment cost (Germany inland and then abroad) plus 19% German VAT on top.
And if I have not managed to discourage you enough, then you may wish to have a look at :
http://www.kuehlkoerper.de/cms/index.php?option=com_content&task=view&id=39&Itemid=87
We found them very reasonable with prices, though Alutronics has, IMHO, better technical knowledge if you need advices.
Patrick
Thanks a lot, Patrick! I knew you would come to the rescue😉 Heatsinks are always too small, mark my word...He-he. Mark Patricks words, heatsinks are still too small....😎
This doesnt help an awfull lot, but if you are in doubt, make them bigger!!
Steen😎
Many people like BIG heatsinks. A matter of taste I guess.
I try not to go much bigger than 420mmx50mm in section. Any length beyond 200mm (along the direction of extrusion) is not really adding value, thermally.
So what if temperature is still too high ?
I seriously considered adding water cooling (actually did), but then you either have to use running water (not exactly cheap in Germany), or use some sort of PC cooling tower with a pump (not noise free and also not really cost effective). But recently I am really tempted by these :
http://www.noctua.at/main.php?show=start
You might be surprised how much it helps, even if you run it at reduced speed (voltage), and how quiet. And at less than 20 Euros a piece, very cost effective. 🙂
Patrick
Better pictures from my Amps
