This is not the safest tool in my drawer, but it's the one I'd run into a burning building for (the building may be burning because of this adapter).
Just try to find one today:
Sheldon
Sheldon
Just try to find one today.
And it's a good thing that you can't!
"Suicide cords" were a common alternative to that. Just a basic power cord, plug on one end, and a pair of clip leads on the other. Used to clip mains power to a transformer for test, or to get power to a power supply subassembly when the rest of the mains connections were in a chassis elsewhere.
Good for those who like to use power cords for outdoor speaker cables.
There's no better woofer test than plugging it into a 60Hz, 120VAC outlet.
There are safe alternatives, with shrouded connectors for bare wires, a lid with a power interlock and a power indicator. One available in the UK is called Rendar Safeblock (or something like that).
That is great, definitely from a bye gone era. In reality it is no more dangerous than a $2 cell phone charger from China.
I call it 'wife-be-gone'. Plug the adapter into the AC outlet and give your wife a piece of speaker wire and ask her to connect it...
The Quicktest mains connector is a safer alternative that is actually quicker to connect to:
CLIFF Electronic Components - Quicktest
Unfortunately I haven't found anything similar marketed in North American.
Clive
Clive
I've never seen one. However any local hardware store sells replacement male plugs which open up and have three screw terminals. It would take a few moments longer than the wire clips in the Safeblock, but other than clip wires, I can have one on the end of a power cord in a minute or two.
- Design & Build
- Equipment & Tools
- Wall plug to binding posts
