Hello Guys,
I am looking for a DIY speaker project to build. I need fronts and center which will be wall mounted right around my TV. I am looking for excellent clarity and strong mid-bass.
I was considering the Zaph ZA5 center speaker plan.... I would build 3 of them and use for left, right and center. Good or bad idea?
I was also considering the RS722 speakers as the woofers are bigger and the tweeter seems to be better, but I am not sure if it was designed with wall mounting in mind...
What are your thoughts?
Are there better projects out there?
Here is an option with MLTL flat wall mount for A7:
http://www.diyaudio.com/forums/full-range/260758-full-range-wall-home-theater.html
