wah pedal - isolated grounds?
your schematic does not show the battery switching arrangements,
and as you say does not show the grounding arrangements.
The case should be grounded, but not used as the output connection.
You need a switching jack for the input, You can get insulated /
isolated metal jack sockets.
🙂/sreten.
better be grounded!
If you want the guitar amp isolated from the wah/input in terms of ground, use a 1:1 transformer at the output. The incoming signal into the transformer still needs to be grounded to the Batt and the input and the ground side of the circuit.
_-_-bear
