W5-2143 vs Peerless NE149
Anyone done a comparison of these two drivers run full range? While the NE149 is marketed as a midwoofer, the published response shows it is quite capable of fullrange operation.
The NE149 gets a lot of praise from multi way users as some of the finest midrange quality, high end SEAS and ScanSpeak reference from a drive unit less than half of the big boys which is what started my query.
There is a rise in the response of the 149 centered in the 8khz region on axis but I wonder if that can’t be smoothed out with baffle location? Is there any way to simulate that?
I do see the off axis response drops like a stone above 10khz but that’s perfect for me as I intend these as nearfield monitors
I do believe by the specs the 149 to be the better for LF extension unless someone knows otherwise?
Thanks again!
I have used the sbacoustics midwoofer metal drivers as full rangers before.
For the 5" midwoofer, the frequency response at 20kHz is about 10db higher than at 1kHz.
I guess it doesn't fit their requirements on how one should have flat frequency response across all angles... in which case most full rangers don't fare very well..
Oon
