Gave this a quick check to see if I'm the right ball game.
The 13mm slot vents (wood pieces) are big enough, was a little worried about that.
As it sits here, the Fs is 45hz (too low) can simply trim vents down to raise it.
Generator & volt meter test:
35hz @ 4 volts
45 valley
85hz @ 7 volts
Going strong to 50hz, there is a dip around 100hz, but haven't trimmed/raised the tuning yet.
The speaker sounds pretty smooth
35hz @ 4 volts
45 valley
85hz @ 7 volts
Thanks Dave...all ready staying up at night thinking about dots
My drivers are a little different, they have a flat back (magnet) which I might glue cork on.
I might re-do the silicon; it looks messy now, will try a softer brush. Will slip a piece of paper in the VC for protection.
My son stopped by, I had Alan Jackson on; he was amazed at the sound.
[all my good CDs got stolen at work, so using sons collection. The Alan Jackson CDs are very well done recordings (btw, he has 50 top hits). I never would have thought light country would sound good on small, single cone speakers]
They do sound very nice, I didn't hear the "plastic" sound. They are dipping down pretty low; sound like a 7" in a BR box. However I want to raise the bass level just a bit, just for the wow factor. I'll try a BSC. Although, the bass really dips down (sub woofer territory) 20' away....wavelength I guess
All said, they didn't quite have the same depth and imaging as the fostex with the mods, not bad though, might make some more.
btw, ordered the expensive wool $50 bucks, its not fluffy enough; 7oz just filled 1/2 the box, so I tuned them upside down (gravity). Back to the craft store, might have to open a few bags; they have racks of different textures.
....all my good CDs got stolen at work, so using sons collection....
All of my music is stored on two different computers and three different hard drivers. The CD's are in boxes. I have complete lists and receipts for my downloads. Security: Two or more copies that cannot be subject to a common disaster.
Bob
I guess you are just spooling .wav files off the hard-drive? What are you using for the pre-amp?
I know what I'd like to try/find; a good preamp with digital input. The Koerica player I'm using has a RCA digital out, never used it.
(when my buddy and I looked for a good player and found the Koerica;we went to several HiFi shops, it did stand out as a better sounding player)
Its a fun little speaker build; sounds like something much much bigger (only 16" high).
Would need a table saw; bench top saw would be fine.
Yes Kyocera.
*It's dead on 16" tall, which was a fluke, since I worked inside out. The base plate aslo has even numbers: 9" - 11" etc.
Yes Kyocera.
Any number can be "even" if you use the right units -- even if you have to invent your own :^)
dave
update
Now that the speaker has some hours on it , it sounds different; the bass is taking over. It is really strong, but natural sounding. I think the wide flare ports enhance the bass (a lot), or maybe the silicon (which I could remove).
[it does not need a BSC]
The imaging is nice, a very nice sound stage, my only complaint is it could use a little more sparkle on the high end.
Maybe a tweeter, rolled off very high, not sure the woofer would need much help (rolled off), maybe nothing at all.
I have a pair of DIY set-on-top tweeters, they look better than they sound ($10 bucks). I'll give them a try with a really small cap.
- Full Range
- W5-1611 SAF - The Sequel
