Two VRDN boards for sale, fully working as I used them for my DAC.
Asking EUR 30 each or EUR 50 for both plus shipping to The Netherlands.
It appears your assembled boards chose the less-frequently-seen arrangement of transformer secondaries. I recommend you create a new message in this thread, explaining the situation to potential buyers in some detail. As-assembled-by-you, which transformers work with those boards, and which do not? Then perhaps explain the additional work required, if they need to use the more-frequently-seen arrangement of transformer secondaries.
Fair point!
These VRDN boards are assembled to accommodate single secondaries.
So for example one VRDN accepts a single 15 VAC secondary on its input and on its output it presents both positive and negative DC (e.g.+/- 18vdc).
See VRDN thread to change this to regular double secondary input and output.
Below is a screen from that thread with required changes:
