hi all just got one off these and yes i know about that tiny fcc anyway i did my search and not too much info what id like to know is the size of this little sucker so i can order the ext. i counted 20 pins and the connector is less than half inch wide wish i had a pic
hey ive got some crappy pics sorry i dropped my digi cam a couple weeks ago here 1
and another
now ill need to extend this like 10 inches can smeone please help me there r foresureley 20 pins
![IMGDEAD]](/community/proxy.php?image=http%3A%2F%2F%5BIMGDEAD%5Dhttp%3A%2F%2Fwww.filelodge.com%2Ffiles%2Fhdd2%2F10377%2Fcam1.jpg%5B%2FIMGDEAD%5D&hash=20d9af30435a634686ed17d4ccd03f65)
![IMGDEAD]](/community/proxy.php?image=http%3A%2F%2F%5BIMGDEAD%5Dhttp%3A%2F%2Fwww.filelodge.com%2Ffiles%2Fhdd2%2F10377%2Fcam2.jpg%5B%2FIMGDEAD%5D&hash=b607ea7c67c319b6757fa5452703357e)
has any one had any sucess with an ext it is actually 1cm wide will lumen lab fcc s work for this
The 20 pin lumenlab FFC cable will probably work although I have no experience of this screen so can't be 100% sure. If the cable is definitely a 20 pin 0.5mm pitch FFC then you shouldn't have any problems, it would be worth you taking a better picture next to a good ruler in order to make sure your cable matches the specs.
