Btw, can anyone suggest cheap analog for SJB6150 / SJB7150 transistors...?
Would it be good choice to replace SJB6150 / SJB7150 with NJW0281G / NJW0302G
SBJ pdf: http://www.semiteh.com/admin/173/upload/semiteh-109202312.pdf
NJW pdf: https://www.onsemi.com/pub/Collateral/NJW0281-D.PDF
Thanks for suggestions!
Do not put too much effort to this amplifier, if you are not absolutely sure that you want to fix some junk (output power is something around 2x100Watts in reality). Many of those skytecs etc. are self destructing (bad design flaws in amp circuits).
Anyway, can you put some images of the guts / boards?
