volvotreter 38hz tapped horn
The 1139SI will be very close to the SG. Should drop in without an issue.
I'd also consider the 25Hz TH originally designed for the Exodus Anarchy 6.5" midbass. I used some W6-1139SG drivers in those and was very very impressed.
Chris
I have build one of the volvotreter subs with the w6-1139SI. See my gallery
Although these subs go pretty low with this 6.5 drivers. I could not manage more then 17.6 volts into it and it lags in the 'loud' department meaning you need to build at least 3 or 4 of them to make some impression. I say up the ante and go for example the martinson THAM10 HT (or HTL)
