No I have not. I was just wondering if a transistor would work there as a form of a switch. Then if so I was going to try it with a test run.
Opto-couplers would probably be the next best option for the steering wheel. You could try the relay to see if it will work. It would definitely work if you used a 555 to create a series of pulses instead of a single pulse for each button press.
A toggle-switch to select encoder or steering wheel controls may be the best option if the face is going to be hidden and rarely used.
cmos 555
free running at 50% duty cycle
operate off of 5v regulator
3-5Hz but will need to be adjusted to switch at whatever rate you think is best
http://www.ti.com/lit/ds/symlink/lmc555.pdf
It worked great. Made a couple changes and ran 6.7 Hz. Thanks again! I'll post a diagram eventually incase other people want to do the same thing. Thanks Perry
Thought I'd revive this thread rather than start a new one.
I have the opposite problem to the OP.
I want to use the Radio Volume dial on the dash of my classic car to control the Pioneer DEHP88rs head unit volume (because it's easier to reach and the Pioneer dial also does programming if you press it - which is a PITA while driving)
I'd like to replace the old variable resistor pot behind the knob with a digital volume pot and run it through a Steering Wheel Adapter into the Wired Remote input on the headunit.
My problem is finding a 12v digital volume pot/controller which will "talk" to the adaptor. It must be rotary.
Do such controllers exist?
Am I chasing an impossibility?
Any advice much appreciated.
Jeff
Jeff
- General Interest
- Car Audio
- Volume control with rotary encoder and pushbuttons?
