Volume control using a DS1802
I was reading the datasheet for the DS1802 and was rather disappointed that I could conclude it is not possible to use dual supply analog signals. I mean pos. and neg audio signals are not possible.
I need to use V+/2 as vitual ground for the audio signal?🙁
So I apply Vaudio+(V+/2) at the high end of the resistor chain and AGND at the low end. This means I need caps at the input and output to get the DC-offset out of the audio signal. 🙁
Are there alternatives for this devices where I can use dual supplies? (±5V)
Hi neighbour,
I used the DS1802 three years ago in a preamp. I didn't had a problem with it. I just used the ground of the supply as the "-" and set a regulator (78l05) between the +15VDC from the rest of the electronics and the DS1802.
I don't use the IC anymore. Actually, I've almost not used the IC.
My plans changed in the middle off the progress. But I can say that it worked 😉
So if you have any interests, let me now?
Ben
Bensen said:
Hi neighbour,
Ben
From Bree? Nice maybe we can meet sometime 🙂.
I'm still in the design-fase. So looking onto alternatives is still very important.
In the meantime I found the application note 161. That discribes the way the DS1802 is best implemented. Doesn't look that bad but I'm not such a fan of adding DC first and then removing it again.
Certainly we can meet.
I've read the app note 161 to. So, what I was saying in my previous post was nonsense. If I used the ground (what I did) as "-", it wil clip everything under gound level :smash:
I sayed that I almost didn't used it, only for testing. Probably I was drunk when I did that. Probably to many Opsale's. 😉
Remember, you can request free samples.
Ciao
Ben
Ciao
Ben
I've checked and only the power up situation is described. The reason I ask is whether or not the signal will be "popped" when power is removed. For instance if zero-X is disabled, and the chip runs up/down the ladder, then will be a transient DC at each resistance change.
I'm just trying to figure out (or avoid) the extra protection circuit.
