Banned
Joined 2002
thnx for the reply - i would rather like a ladder with only 2 resistors allways connected - so my dac only sees constant resistance at his output - but with more than 24 positions- 50 or more would be preferable...
this could be made with relays but I don't know the schematic....
vdi_nenna said:
thnx for the reply
diy - maybe cheaper....
Banned
Joined 2002
Originally posted by
How about feeding a voltage to normally open reed relay DPDT circuit?
You could use a 2 deck 12-24 position switch.
But this would be over kill and is probably a bad design idea
it would not be a bad idea but when, say, 50 positions are intended than one would have to have many resistor (possibly good quality ones) and that would be an overkill to my wallet.
pass soulution is better- less resistors and than combine then - unfortunately I don't have a cluze how to design it and or make the software for the thing......
Banned
Joined 2002
sunrise said:so..... the question is what do we do now..... we don't want to develop it by myself (since my knowledge is in digital sence very limited) and it seems that there isn't any schematics to use from somebody else ::::![]()
Im working on a balanced and Non balanced volume atenuator digital with OUT relays and a display with remote and input selector if you want to wait a little ill have it done soon.
J'
J'
I have told a friend of mine about my suffering
regards
- volume control similar like aleph p1.7
