Voltage out of tube rectifier?
attachment.php
If I apply 260v in how much do I get out?
Is it the usual AC x 1.41 or?
And the transformer's windings have resistance as well, secondary and reflected primary. The voltage drop is not easily calculated, since the current is discontinuous, large peak current for a portion of the AC cycle. Use the program PSU Designer from Duncanamps.com. Since it doesn't have a "hybrid" bridge rectifier, run it once with SS, once with tube bridge, average the two.
