Yes, but less the voltage drop of the 6Z4 (around 23V), and also less the 15V drop across the 100R.
So roughly 330VDC at Vcc.
https://frank.pocnet.net/sheets/127/8/84.pdf
I think it is this one:
https://frank.pocnet.net/sheets/112/6/6C4PEV.pdf
https://bms.isjtr.ro/sheets/095/6/6Z4.pdf
And the transformer's windings have resistance as well, secondary and reflected primary. The voltage drop is not easily calculated, since the current is discontinuous, large peak current for a portion of the AC cycle. Use the program PSU Designer from Duncanamps.com. Since it doesn't have a "hybrid" bridge rectifier, run it once with SS, once with tube bridge, average the two.
Also your AC line voltage can vary widely, by 10% or more.
Not to mention the mfr tolerance on the winding ratio.
Why not make a full diode bridge, and run the four tube sections in parallel? if the tube shorts internally, it wont take out the transformer.
More like 250V. This is indeed a clone of Soviet 6Z4P.So roughly 330VDC at Vcc.
- Tubes / Valves
- Voltage out of tube rectifier?
