Voltage on TDA1541´s decoupling pins...
Who will be so nice to measure the voltage on the decoupling pins of the TDA1541a? The reason is that I have some troubles with the bass reproduction.... compared to some other DAC´s it´s a very "hidden" bass and it seems to me that there is a lack in the region of ~100-200Hz :bawling: I have not had this with my (now recycled) non-os 1541 standalone dac... the current one is located in a Sony CDP. didn´t had the chance to do any frequency dependend measurements (= no scope :bawling: )
P.S.: Decoupling is very well improved, I/V is currently active with AD8620, muting trans. removed....., the TDA got it´s own 78Lxx (may they be to small?)
Thanks in advance
It is a bit of a characteristic of the TDA1541 to have a bit of a indistinct bass. This is more related to the DAC chip itself it seems. Paralleling may improve matters.
Do a google search, Lesha has a TDA1541 page with the voltages he measured....
Thanks Zodiac!
Yeah, might be a property of the TDA, as I compared it to some TI R2R DAC´s they all have the same bass.....
I should have known this, every ciompany has it´s own sound, is it in opamp or even dac´s.... But with sigma-delta it´s more complicated.... I don´t like them....
But I´ll play a little bit with the capacitor´s surrounding the TDA, there may be a possibility to "tune" bass to my flavor...
Thanks again....
yes, thanks again!
Well, I measured more or less the same voltages beside output voltage, it´s about 3V, forgot if it´s + or -...... I´m using an ordinary active I/V with AD8620.... and therefore this voltage also exists on the opamp output.... coupled only witha 6,5V OSCON... Maybe he don´t likes that high voltage... As soon as I get my 35V/86µ Cerafines I´ll know if that gives me an improvement....
It´s a shame I´ll have to wait for the weekend :bawling:
