Volt meter recommendation
Joined 2007
Hey,
I’m looking for a digital volt meter for testing an f6 amplifier. I need to set bias and offset accurately. I have a fluke 110 but don’t think it’s accurate enough. I’m not opposed to buying something used or older but it has to be reliable and accurate. I can probably spend $100-150.
Suggestions please
Any multimeter is perfectly adequate for this. +/-10% for bias is neither here nor there, and a resolution of 100uV or better is typical for most multimeters which is way way overkill for offset measurements (anything under 50mV is basically fine)
PS why cross-post? Don't do it!
