Volt BM 2500.4
TOO MUCH.
Look at the specs for your speaker:
BASS MIDRANGE LOUDSPEAKER 250mm (10")
Bass Midrange in Studio Monitors
FEATURES: The BM2500.4 uses a massive magnet with a symmetrical field, extended pole and long voice coil for maximum linearity. The cone, linen surround and dome are critically matched and doped to ensure very low midband colouration. The result is analytical sound quality with a stunning dynamic range. The BM2500.4 is designed for use in two way nearfield studio monitors where accuracy and realism are essential.
Not being an expert on subwoofers common sense tells me this speaker is not ideally suited for the task:
Nominal Diameter
250
mm
Power Capacity
200
watts
Sensitivity
92
dB/watt/m
Frequency Range
25-2500
Hz
Impedance
8/16
ohms
Bl Factor
15.5
N/A
Voice Coil Diameter
75
mm
Voice Coil Material
Copper
Maximum Excursion
25
mm (before damage)
Magnet Assembly Weight
8.1
Kg
Effective Moving Mass
0.048
Kg
Compliance
0.0005
M/N
Volume displaced by unit
2
litres
Connection
Metal push terminals
Chassis
Painted diecast aluminium
My feeling is you're going to pay a substantial amount of money for a well extended woofer and throw away a lot of that bandwidth in the process.
Many alternatives exist but it's hard to recommend anything at this point.
Cheers,😉
Re: TOO MUCH.
I think Frank is making the right call on this. It is an extended range woofer, not a subwoofer. I am sure it is excellent for what it is designed for, which is to extnd up to a tweeter and still move a fair amount of air.
But for subwoofer duty, i bet any number of the dozen or so mid-priced and very competitive 12" would handily outperform it for a fraction of the price. And if you wanted to spend the same price...
dave
Adam said:
Ok, so what driver would U use?
I live in Poland so some of american drivers are unavailable here.
I believe that better value can be had if you can minimize the shipping you have to pay so i'd rule out the yankee drivers.
The Peerless 10 & 12" XLS come highly recommended.
But i also wonder if there are any sleepers made locally or close-by (former Soviet Union) that would be worthwhile pursuing?
And i always like to use subs in pairs if i can (push-push is a cheap trick to get better performance.)
dave
Adam said:
Isn't this config called Isobaric??
Not usually. It is possible to make a push-push isobarik but really gets convoluted.
Both drivers face the outside world and are in phase but are mounted such that the reactionary forces are cancelled, dramatically reducing the load on the box and improving the micro-dyanamics.
dave
