Vituix help
I have looked at threads, and tutorials, but cant figure out why my graph readings don't change on the crossover page. I can put any component in the crossover circuit, and none of the graphs move. The original graphs made by the speaker files are present, but nothing changes. Is there a more complete turorial somewhere on line? Thank You.
Wiring
I found that you have to run your wires to the components in your crossover.
Right now, you have a wire running to the driver and you are bypassing the components altogether.
Delete this wire, then run your wire from amp to components, then from there to your driver.
Make sure you've got your grounds in place.
Have fun!
