Visual Analyzer - sweep function
Under Detailed Features about generator, it says:
Predefined waveform : sinus, square, triangular (parametric), white noise, pink noise, pulse, sinusoidal sweep,
so it should work. You may have to email support if there is any. Program looks good, but latest version is 2014.
Finally got it working. I was trying to run it under the sweep tab but that is just part of the config. You have to change it from the drop down box in the main tab.
