Does anyone have any recommendations as to where to buy some Vishay S102's, Z201's, TX2575's or TX2532's...PartsConnexion sells the TX2575's at about $15.95 a pop. PercyAudio carries some of the TX2532 starting at $11.95 each. Any help would be appreciated.
Vishay resistor
You can contact with Texas : Texas Components - Precision Resistor & Microelectronics
I bought froorm them a couple of times already.
Thanks,
vadimgal.
Thanks,
vadimgal.
Look also for RNC90Y or -Z. Vishay foil resistors are occasionally found on Ebay, if you search under part numbers and "Vishay resistor" or "foil resistor". I use broader search terms like rnc90* to catch more instances of complex part numbers with that term embedded.
Also: Metal Oxide, Carbon Film & Metal Film Resistors at Surplus Sales of Nebraska.
Percy Audio carries the VSH line of bulk metal foil resistors in a conformal dipped package at considerable savings; not quite as good as Z foil but still better than most metal film resistors.
Thanks,
vadimgal.
Which model(s) did you purchase and if you don't mind telling us, what did you pay for them? Do they have an online sales division? Thanks.
