VISHAY's
Does anyone have any recommendations as to where to buy some Vishay S102's, Z201's, TX2575's or TX2532's...PartsConnexion sells the TX2575's at about $15.95 a pop. PercyAudio carries some of the TX2532 starting at $11.95 each. Any help would be appreciated.
Look also for RNC90Y or -Z. Vishay foil resistors are occasionally found on Ebay, if you search under part numbers and "Vishay resistor" or "foil resistor". I use broader search terms like rnc90* to catch more instances of complex part numbers with that term embedded.
Also: Metal Oxide, Carbon Film & Metal Film Resistors at Surplus Sales of Nebraska.
Percy Audio carries the VSH line of bulk metal foil resistors in a conformal dipped package at considerable savings; not quite as good as Z foil but still better than most metal film resistors.
