Very long time I haven't been here. After trying a full-range and finding it not to my taste I decided to go back to more conventional speakers. I had a couple of Visaton DR45 and TL16H around for years. Most obvious choice would have been the Monitor 890III but after looking at the woodwork.... I decided to go with less ambitious woofers and a simple prismatic bass reflex. Housing at about 100 liters is a bit too small for those 2 woofers. But it should give me to about 60HZ.
First try of the parts. Looks OK to me.
Speakers:
bass: 2x W250S 8 Ohm
mid: DR45 + M300
high: TL16H
Still a bit work to do. Fitting the BR pipe, wiring, bit of damping and a coat of varnish. Then the amplifiers...
I'm just not sure about the low-mid range. Having that crossover at 800Hz looks high to me.
Speakers:
mid: DR45 + M300
high: TL16H
That’s a cool looking mid horn. Did you build or buy it? Do you have the build sheet for it ?
