Virtual ground / Rail Splitter using only LM317
Hey guys,
sorry for this probably very basic question, but with the mess that the "search" function is returning I could not easily find my answer.
I wated to build a rail splitter for a headphones amp out of what I had in stock.
And I have Lm317 and only that.
So I've designed a circuit that works when simulating it.
I wanted your opinion.
Would that work ?
(the strange resistors values comes from what I have in stock too).
Using lower values of resistor lowers this impedence but it also increases the current draw on the power supply.
The opamp buffer allows a lower impedence for the virtual ground.
This works of course depending on your application and current levels required returning to the virtual ground. jer
