Hello,
I have a pair of Philips "MFB Electronic 22 RH 532" speakers, housing built-in amplifiers - a free gift from my in-laws, who bought them 30 years ago...
The tweeters & médiums are dead. Philips does not seem to be able to replace them. I just called Philips France, to learn that they no longer make loudspeakers : Marantz provides them...
Does anyone know whether these tweeters & médiums are still available ; or, more probably, what are equivalent models can be used as replacements?
References :
• tweeters 2,5 cm AD 0160T
• médiums 12 cm , AD 5060 Sq
(output 20 watts)
What would you recommend ?
Thanks !
Eric Mounier
(who never throws anything away)
References :
(output 20 watts)
Thanks !
Eric Mounier
http://www.mfbfreaks.com/ENG/index1.html
you could try contacting them, the forum is in Dutch though
Number of speakers : 3
Low unit : AD 8065 /MFB
Mid unit : AD 5060 /Sq8
High unit : AD 0160 /T8
Number of amps : 2
Low amp power : 40 W
Mid/high amp power : 20 W
Output capacitor amp :yes
Cross-over : 500 Hz (active) + 3500 Hz (passive)
Year of birth : 1974
Remarks : Very first MFB based system.
Replacing the tweeter is straight forward, the mid may be difficult.
Does the mid have a closed back ? or its own enclosure ?
Does the passive crossover contain any resistors ?
You sure the mid/high amplifiers work ?
Are all drivers open circuit ?
sreten.
Number of amps : 2
sreten.
I just picked up a mismatched pair of these last weekend (i've seen at least 3 flavours) but run across them fairly often. (ie a matched set siting boxed up ready to ship to a client)
The 5060 is used as a very small bandwidth filler driver and is essentially a 5" whizzerless FR/midbass in a small plastic enclosure. I may have a set of these sans enclosure (with a different designation)
These were very common DIY items over here in the 70s so should be fairly common and "relatively" easy to scare up used. Some patience may be required.
dave
Hello!
The SQ-5060 is out of production but replacemnent SQ-50600 can still be found at some speaker stores, dont know if it is still in production.
Look at www.hifikit.se for instance
Use the search function and type in "philips"
You will see the 50600 and a copy of AD0163.
The AD0163 is, as I understand, the third generation of AD0160.
I hope this can be of some help to you.
Best regards
Martin Dellstig
Best regards
Martin Dellstig
I have a limited supply of AD 5060; AD 8060/W8; AD8065/W8; AD8066/W8 etc available for sale. If there is an interest, I may be contacted at tracer740@rcn.com
Sound is what is happening wherever there are ears to perceive
Music soothes the savage breast. ...
- vintage Philips loudspeakers
