Vintage Philips Kino Speaker
Last year I purchased a pair of Philips 12" drivers from 1952 with phenol spiders. The model number stamped is "2278-00". I have not been able to find any information about this driver. Does anybody have information? Thanks a lot in advance!
They came from a cinema installation in Germany, where they had been mounted in 2x2meter open baffles. I have been using them for a year now in 1x1m baffles, however not quite large enough to support a sufficient low output, so soon I will make sealed cabinets of at least 150L with wide frontbaffles, also considering an aperiodic port. Suggestions are welcome! One of the units has been measured: Fs=50Hz Qms=14,55 Qts=0,27 Vas=155 Impedance=16ohm.
Impression of these drivers is a lovely present reproduction, fine resolution to around 4Khz, a gently roll-off.
Kind regards,
Thomas Groendahl
Copenhagen.
Musical interest: Jazz and classical.
System: EMT 930 turntable, 2A3 SE amp.
Philips 2278-00 spider
Hi Tomtt,
Currently I only have the sellars photo of the drivers spider/centering device.
I will have more detailed photos made asap for posting.
Thanks for the link, that field-coil Philips 2088 looks great, the model-numbers reminds..
Thomas
