Vintage CD Player woes .. need to pick the brains of the techies in the house.
I have a CD player (B&O CDX) that once turned on, has to sit for 5 - 10 mins before it can be played. The strange thing is how it tells you when it's ready to be played. I press power, don't touch anything else and just let it sit .. 5 or so mins later, it will emit a loud static out of the speakers, which will then slowly taper off over about a minute. After this, I can play the CD no problem (with a bit of static here and there). If I try to play a CD before that, it will just sound distorted until that same 5 or so minutes passes, then the sound clears.
I'd look along the path of digital sound reproduction.
The SAA chips are known to fail; the fault description points to digital RF audio stream handling issue. check the two polystyrene capacitors, 3 transistors and the SAA7010 located close to that white trimpot and white labels... You need a schematics and an oscilloscope for this.
Polystyrene caps can start to short if mistreated (close proximity to heat from the soldering iron, mechanical stress...)
The 1540s are most likely okay because both channels are affected the same way, at the same time.
Good luck
Good luck
Just replaced the SAA7010 and resoldered transistors. No change.
Good luck
You really have two options:
1. continue replacing parts, one by one - which still does not mean the ultimate success (there might be a cold solder joint somewhere, or a tiny PCB track crack - these are difficult to spot...)
2. Get the oscilloscope and the schematic with waveforms, and then start from the ingress point from the CD mechanism, and then work forward.
I do have the schematic and I have inspected the PCBs which appear to be in good shape, there is one lifted track, but still connected. Replacing parts is OK by me as all the parts I paid for (caps, reeds) needed changed anyways. The rest of the parts are coming from a second CDX I have that doesn't read discs. Hopefully I will get lucky and find the part causing this and be able to replace it from that machine. I do not have access to an oscilloscope.
I still think you should pursue the freezer/heat theory. Why not try heating a small section of board at a time (with a hairdryer) and see if it starts working immediately.
Due to the top loading design, the only board that can be accessed while this machine is running, is the decoder board. I have done the freeze spray on it, however, I have not tried heating it. I will give this a try as I do suspect the issue is on this board.
