Anyone knows where i could get more specs on that driver?
and anyone here ever used it?
Vifa D19TD05
Vifa D19TD05
vifa driver
partsexpress carries it, it's their part # 264-500
From the PE blurb:
Affordable 3/4" poly dome tweeter features good dispersion and excellent power handling. High loss diaphragm. Voice coil is ferro fluid cooled. * Power handling: 80 watts RMS/115 watts max * Nominal impedance: 8 ohms * DC resistance: 6.2 ohms * Frequency range: 3,500-20,000 Hz * Magnet weight: 3.7 oz. * Fs: 1700 Hz * SPL: 89 dB 1W/1m * Net weight: 3/4 lb. * Dimensions: A: 3-11/16", B: 2-3/4", C: 7/8", D: 2-5/16", E: 11/16"
Data Sheet:
http://www.partsexpress.com/pdf/264-500.pdf
Good Luck!
Matt
From the PE blurb:
Data Sheet:
Good Luck!
Matt
