Does the Nextvision N6 support 16:9 output to composite video?
I ask this because I plan to build a projector from a 7" Lilliput. I connected my VCR to the LCD and the image was stretched horizontally.
Does the N6 support PAL?
In the specs of the N6 I find that it supports 852x480, but the Lilliput is 800x480.
Will this be OK or will my picture be bad?
Or are there other alternatives to view TV on a 16:9 display?
I don't want to run it through a PC.
I searching for a TV tuner that I can use for my 7" LCD projector that I'm building. It's from a 7" Lilliput and that has an aspect ratio of 16:9.
The tuner i'm looking for must have an output that can be selected for a 16:9 screen on composite out. It's like a a widescreen TV but without the screen, I only need the tuner.
Regards,
Davy
Regards,
Davy
