I am considering changing the video op amps on the output of my dvd-player.
The current ones are Toyo TK14520 which I think are very similar to Motorolas MC14577.
The data sheets don't show much details on their performance but I assume there iis room for improvement.
Does anyone have any experiance wrt these opamps and/or replacing for more exotic types?
Thx
Thx
Are you not satisfied with your picture quality? If not why change? Even if you were I doubt that just a shift can do good.
OK, the IC isn't best around but 10 MHz bandwidth for a ordinary TV is OK. Consider that a VHS machine has 2-3 MHz.
Hej Per Anders,
The picture is great (NECHT1000 and Denon 2900) but as always when one gets used to it.......and starts to think it could get better..... 😉
This is a progressive scan PAL player and I think that means that the luma channel runs up to 5-6Mhz?
Anyway a year back I was fiddling with an old interlaced player with many PQ issues. I ended up ripping out most of the analog video circuits (based on the dual MC14577), replaced them with the Burr Brown OPA620 (single) opamps and a separate power supply.
The improvement was significant, besides a much more solid and defined picture most of the obvious artifacts disappeared, actually pretty similar to what gets discussed wrt audio.
I will not redo this one as much just yet but figure I could play with the power supply and the video opamps if it would improve things.
Now, even though I have some experience myself I can't say if the improvement I experiences was due to better power supply and/or better spec'ed opamps as I did it all at once...hence my query.
One of the possible direct replacements I've found is the
MAX4216
which seems to measure ok.
I am cautious wrt to dual opamps and would really appreciate any other experience out there?
I guess the OPA842 or MAX4108 would be good but they are single and could not be plugged in without another board which will be risky considering their bandwidth.
MAX4216
