I just got a Sharp QA-1500 and I can not get a picture with plugging into the video jack? The screen just says "no input"I don`t have a remote and I don`t want to take it apart, yet, to check inside.
Can anyone help? Does anyone have a manual? Help! I don`t know what to do.
Hi Lotus,
I have a QA 1400, which is supposed to be identical to the 1500 except for missing a pcmia card.
The remote has an "input" button, which switches between the VGA and the video inputs. If no input is active, then none of the on panel menu functions seem to work either.
Do you get a picture if you hook up the vga input? that may be a way of accessing the menu's...
Hello Lotus 7,
I don't really have a reply to your actual post. I just noticed your name! I've owned an Esprit and now a Europa.
jeff
jeff
I got qa 1500
to get it to work you have to hold down the + button and press select sometimes it comes up blue but just do it again and it will be fine!
doodles
doodles
Thanks guys
Thanks guys.I don`t have the remote and I did use the buttons at the top like you said and I got my picture! Thanks for helping.What features am I missing by not having a remote?
Thanks again!
Thanks again!
features
you aint missin none! you can do it all on the panel
Have you been through the menus and found your colour and stuff? there are a few options>
Have u got it linked to your pc? If so what lead do you need as I am only using it for tv and xbox at the mo but I want it linked to the pc!
Doodle's
Doodle's
features?
No I have no idea on getting those other features from the buttons on the top. Can you explain the procedure ?
Like yourself I am only using the panel with my Xbox for movies and games.
thanks
thanks
Hold down menu for 1 sec and a blue panel comes up! use arrow keys to switch between them and then select to choise the option u want! to come out of it all just press menu 2 times.
I think thats about it cos the menus explain themselves!
If u get stuck or have any probs let me know and ill try to help
What is your pic quality like as mine seems abit blered!
Running on ohp HANIMEX A4100 250W
Problem with sharp qa-1650
-Hello,
i received a sharp qa-1650 panel today.
The only problem seems to be that the panel powers up and projects
only the start up sharp logo!!!I can not see video or anything else.
The menu buttons just do not respond.Is there anything i should know?
I never had this panel so please provide me with info in what to do
to project video and not just the start up logo.
Thanx a lot
Papanastasioy Spyros.
-Hello,
Thanx a lot
picture ok
I`m running mine on a 3M 9200 overhead.It has a triplet lens and I find the picture ok.This is my first projector so I really have no way to compare my picture quality. Next month I will be improving my screen so things should only get better (until I can afford a video projector!)
mine is fine on tv just the xbox pic aint as sharp as it should be! the pic looks soft if u know what i mean.
Doodles
what is your bulb?
Doodles
what is your bulb?
- General Interest
- Everything Else
- The Moving Image
- LCD
- video input for sharp QA-1500 not working
