I'm finishing this amp here and works pretty well the power amp and the 2 channels (normal and bright) but the other channel, vibrato/tremolo is getting a overdrive on instead a vib/trem effect..
I'm trying to test it with a 12ax7 instead a 12au7 (I dont have a 12au7 here, i bought 2 of them, but left 2 weeks to be delivered)... BUT just for test, I changed the cathode resistor from V3 to 47K instead a 1.5K, and the effect dont worked.. Nothing at all of vibrato or tremelo, nothing..
I wanna be sure that's because I changed the tube... Anyone can help? Perhaps explain to me how this effect channel works..
There's the schematic on attachment.
Thank you for read ^^
Copyrighted material removed by moderation. This schematic was clearly marked as restricted use copyrighted material and may not be posted here. You may post a complete hand drawn version of the schematic or excerpts as preferred. Please read the forum rules!
Do you have LFO output signal from V1a, and at anode/cathode of V1b ?
Why did you choose 47k ?
Do you get acceptable amplified input signal at anode of V1a and V1b ?
Tubes / Valves All about our sweet vacuum tubes 🙂 Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum
AND
Instruments and Amps Everything that makes music, Especially including instrument amps.
