I may have missed this somewhere, I got lost in all the F5 posts, but has a Sony VFet F5 been tried or built? I'm referring to the 2SK82/2SJ28 set. I found several amps referred to on the web, but they all had capacitors in the output stage. I would like to avoid that if possible.
search for meaning of depletion and enhanced mode biasing
those Vfets , being depletion mode , aren't so convenient to implement in F5 concept
I guess I should have said a simplistic amp design using the Sony VFEts, without caps in the output stage. The amp I was referring to was designed by F. Corrado.
I know that one
nothing wrong with cap position - sort of part of Transnova circuit by Kirkland
whatever - even in common PSU arrangement , caps are in signal path ......
I have built an F5 type circuit with the Sony parts. It works fine, but the
heavy depletion bias voltage makes the circuit more complicated, so I'm
not rushing a DIY project out.
- VFet F5
