I'm afraid I can't tell you right now. It's a multimillion dollar project and the application is very serious.Peranders, let's get serious. What are trying to do with this thing? Maximum performance motors are Extremely application specific.
wrong place
Edit: Perhaps this company is willing to design a motor according to your specs: http://www.magneticinnovations.com
If it's really a ' multimillion dollar project', why asking for help from a bunch of audio freaks?I'm afraid I can't tell you right now. It's a multimillion dollar project and the application is very serious.
You could try approaching a custom switched reluctance motor manufacturer with your application. These can have very high torque at low speed, but optimized speed/number of poles will have to be calculated with the volume of the resultant gear stack and maximum power output available for given motor configuration. This motor type doesn't have a wound rotor and so the IR heat can be drawn away easier with available fluid cooling.
I think 1.8 is not sufficient. you should be go for higher.
Like: Single Phase Electric Motors Melbourne
- General Interest
- Everything Else
- Very strong and very small electric motor
