bypass caps
I put 0.1uF caps from pin 8 to ground and pin 4 to ground. I did it on the bottom side. Pretty small board. I needed magnification to see what I was doing. You could put 10uF from each supply side to ground at the input. It won't be pretty. But it's a buck. Cannot get much cheaper than that.
I got one of theese, if I simply short R5 and R6 it will be unity gain? Im slow
1Pcs Power Supply 12-35V Ne5532 Preamplifier Preamp Board Dc Single Ic New D | eBay
Trace which pins on the chip they link http://www.remotefactory.com/images/8-pin-dip.png
Check the pin numbers against this diagram http://circuits.datasheetdir.com/37/FAIRCHILDSEMI-NE5532-pinout.jpg
Have you a multimeter?
the schematic
R4 connects the output to the inverting input. R3 goes from the inverting input to ground. I think you want to remove R3 and short R4. But even if you leave them as is, the gain is very low. The pcb is not really too terrific for rework. Why don't you try it as is?
- Analog Line Level
- Very Simple Single Stage Op Amp Preamp
